Author Topic: Rebuilding Roseanne  (Read 19697 times)
Re: Rebuilding Roseanne
« Reply #15 on: November 03, 2010, 09:59:11 PM »
Got the case halves together tonight.  Note to self, when using threebond, wear an OLD sweatshirt.  I now have a new old sweatshirt.
« Reply #16 on: November 04, 2010, 11:30:39 PM »
Long but productive night in the garage....
Pistons on the rods.
Starting to drop the cylinders.  Should have bought 4 hose clamps.
Part way down
And then I had to do it again.  Look on the right and tell me if you see the problem.
Cylinders all the way on.  Whoo hoo, couldn`t stop here.
Head on
Cams in, but the timing is way off.  Got too late to continue, so onwards later.
Fritz
« Reply #17 on: November 05, 2010, 10:08:10 AM »
Oh well......"Practice makes perfect"...No stopping ya now....with this weather you will be Ridin' it in no time...
Looks Good Hans....( for a Yamaha  ;D ;D)
Fritz
« Reply #18 on: January 01, 2011, 11:41:52 AM »
How's the Build going there Hans....Are you still waiting for it to Warm up a bit?
Or...are you looking for an MX175 to work on... ;D
« Reply #19 on: March 25, 2011, 11:37:58 PM »
OK, back at it the last couple of nights.  Warm enough to work.  Last night was trying to remember where I left off, and trying to find whatever parts I need to throw at this thing.  Tonight was clutch cover on, clutch pushrod in, measure valve clearances (have to buy 10 shims...), and the alternator and starter back in.  Just have to set the valves and put the oil pickup and pan on, and it's a done deal.
fj1200
« Reply #20 on: March 25, 2011, 11:55:03 PM »
Good on you Hans.   :)
madmac74
« Reply #21 on: March 28, 2011, 06:54:06 PM »
 Are they 13mmm Diameter shims ??  if so I have a wide assortment .....
O an good on ya mate !!!!
MAC :)
« Reply #22 on: March 28, 2011, 07:34:39 PM »
Nope, 29mm. Happened to 'acquire' some. Valves are set, oil pan is on. All would be good if I had the right cam cover gasket. Somehow I got one for an FJ600......
« Reply #23 on: March 30, 2011, 10:26:25 PM »
And...  I think I'm done...  Need to get 4 orings for the carb boots, and should give the carbs a bath at Jeff's Ultrasonic Emporium.
Final product... still doesn't look too pretty, but then she is named Roseanne.
When it comes time, somebody please remind me to tighten that countershaft sprocket.....
Fritz
« Reply #24 on: March 30, 2011, 10:38:26 PM »
Looks Good Hans....Really like the Red Stripe  ;D
Don't forget to tighten the countershaft sprocket..... 8)
« Reply #25 on: March 31, 2011, 11:23:26 AM »
I have a wrench that grabs small sprockets so you can hit their retaining nuts with an impact wrench or a big torque wrench, while still on the bench:  I wonder if it would happen to fit the output on the FJ? I guess a strap-wrench style chain-wrench would be truly adjustable and still take the hit from the impact gun or the torque from the torque wrench...I should build one.
« Reply #26 on: May 23, 2011, 07:39:29 PM »
Got busy today, engine back in frame, carbs on.   figure first fire on Wednesday, maybe.
Fritz
« Reply #27 on: May 26, 2011, 11:05:06 PM »
So.....How's it running?.....
[attachment deleted by admin due to full attachment storage]
« Reply #28 on: May 26, 2011, 11:21:23 PM »
poorly.  something not correct in the top end, gonna have to open er up and have a look..........
« Reply #29 on: June 08, 2011, 10:56:19 PM »
I said frig it tonight, and fired er up again.  Horrid noise wasn't so horrid....  Shut her down, checked the oil level.  Added almost a litre, sparked her up, sounded OKish, getting better as she ran.  Maybe more oil helped, maybe something needed to settle in... dunno, but she sounds mean now, even vicious.  Might have to try and take her for a ride.
