Author Topic: Carb stix  (Read 3273 times)
Carb stix
« on: May 11, 2014, 11:10:19 PM »
Hi all.  I need to sync the carbs on the Blue Meanie at some point in the near future.  Anyone have a set of carb stix for lease?
Re: Carb stix
« Reply #1 on: May 12, 2014, 12:21:18 AM »
Ah, yup;  I have a set.
Re: Carb stix
« Reply #2 on: May 14, 2014, 03:10:44 AM »
 Hey hans i actually have a 4 guage setup complete with restrictors.. yer welcome to it. Works the dogs dangles
 8) Mac
Re: Carb stix
« Reply #3 on: May 15, 2014, 05:06:27 PM »
parker, you dont even use them.. .you do it by ear !!!
Re: Carb stix
« Reply #4 on: May 15, 2014, 11:34:12 PM »
Jet kit is in the Blue Meanie.  Now needs a sync, but.....  the jet kit is supposed to use a K&N for best effect, and it won't arrive until next week.  Should I not bother until I get that in?
Re: Carb stix
« Reply #5 on: May 16, 2014, 03:40:51 PM »
Yeah I would wait,  since that will change everything again.  You will end up really syncing after the Jets.
Re: Carb stix
« Reply #6 on: May 16, 2014, 04:19:11 PM »
  The air filter is actually the only thing you are changing that would affect the sync. Remember, this is an idle only adjustment--I funk mine on purpose to get a brappier idle sound. That being said not only do I have a set of stix I have Stu's as well, sure he would not mind if I gave them to you. The carb that the cable goes to is your base, work out from there. CHEERS.
Re: Carb stix
« Reply #7 on: May 17, 2014, 08:20:56 AM »
Well, I can say this jet kit made a monster difference.  Feels way smoother, got rid of the bit of surging it had at neutral throttle.  And then there is the top end.... wow.  The old jet kit used to cause a problem above 9500 rpm, this now pulls friggin' hard all the way to redline.  The idle is a little rough but it picks up smoothly from there.  I'll wait to get the K&N next week and then do the rest of the tuneup.  Thanks for the offer Wayne, that'd be cool.
Re: Carb stix
« Reply #8 on: May 18, 2014, 01:03:35 AM »
 No problem Hans, can even deliver since I still need to pick up that fender.. . CHEERS.
