Author Topic: Stator - Suzuki  (Read 4055 times)
Stator - Suzuki
« on: May 28, 2012, 03:08:16 PM »
Looking for an early 80's GS1100 G Suzuki - 2 Valve - STATOR
**     Never Mind...FOUND ONE.....
« Last Edit: June 06, 2012, 11:08:09 PM by FRITZ »
Re: Stator - Suzuki
« Reply #1 on: May 28, 2012, 10:57:15 PM »
I can only assume that after your battery was going dead, and the charging system test (while running at Bulldogs's ...I'm a witness) you have ruled out the regulator/rectifier.  While the GS Suzuki's from that era were notorious for frying stators, I hope you have eliminated the reg/rec first.
I sold Mike Beswick a 1981 GS1100 with a freshly rewound and baked stator.   He bought the bike for parts and maybe that is part he never used.  The stator had less than a season of riding on it before the bike was "retired".  Give Mike a call.
Re: Stator - Suzuki
« Reply #2 on: May 29, 2012, 10:37:52 AM »
After the Charging System Output Test Failed unfortunately at BullDog's, I was able to Recharge the battery...disconnected the headlight, and ride  back to the Barn.
Performed a No-Load Alternator Test as per the Book on the Stator - The AC Voltmeter showed no where near the 75 volts needed on each test connection for a Pass
Havn't looked at the R/R yet..... ;D
Fired up the Triumph and went for a ride..then got rained on.
« Last Edit: May 29, 2012, 10:39:31 AM by FRITZ »
Re: Stator - Suzuki
« Reply #3 on: May 29, 2012, 02:43:02 PM »
If you are not getting the voltage, then yes, your stator is likely fried.  Have you visually inspected it?  The last one I had that went (same GS1100 I referred to above) it actually looked and smelled burnt.
