Author Topic: Battery tip  (Read 8613 times)
Battery tip
« on: August 14, 2008, 12:58:31 PM »
      Starting terminal screws can be a beeatch sometimes especially if you have extras like a heated vest etc. Simplest solution I've found is to nip a little piece off of the vent hose then wege it squarely under the nut in the holder on the batt. not only does it hold the nut up it also keeps the end of the screw from corroding.
