Author Topic: Tire Repairs??  (Read 8091 times)
Tire Repairs??
« on: September 16, 2011, 05:22:41 PM »
I have a flat tire and I can't seem to find the leak.
I called the Yamaha shop and they claim they don't repair tires except to check them to ensure the bead is properly set in the rim. Otherwise they repair by installing a new tire!!!!!! The tubeless tire has 5000 kilometers on it and is a good tire. Is this normal practice now?
Re: Tire Repairs??
« Reply #1 on: September 16, 2011, 06:02:52 PM »
  Liability has scared most dealers from doing repairs. If you can't find it you probably have a bead leak. Dismount the tire and clean bead surface of tire and rim. mark where the valve stem meets the tire. line your mark up on assembly so ya don't have to re-balance.
Re: Tire Repairs??
« Reply #2 on: September 16, 2011, 07:11:04 PM »
  Since were on the subject who would be interested in a tire changing workshop? I know some of the guys in the club do there own but how many? Anyone want to learn how?
Re: Tire Repairs??
« Reply #3 on: September 17, 2011, 12:29:16 AM »
I do my own....Always willing to learn some new tricks or tips though....not my favorite chore admittedly
....I'm in.....if I can make it    :D  - Tire machine might make it more enjoyable though.....
« Last Edit: September 17, 2011, 12:33:27 AM by FRITZ »
Re: Tire Repairs??
« Reply #4 on: September 17, 2011, 09:11:50 AM »
I certainly don't mind hosting a Tech Night on tires. I would need to buy the correct tools and I am not sure if I should buy or need over the long term a tire changer (I don't even know the cost).
I need (want) my motorcycle back so I think I will inflate it up to 50 psi to see if that seals the bead?? Maximum tire pressure shows 42 psi.
Monday or Wednesday night is available at my house garage as I don't want to interfere with one of the last few rides on Tuesday night.
Re: Tire Repairs??
« Reply #5 on: September 17, 2011, 09:50:54 AM »
A tech nite on tire changing would be great.  I use to do my own tires decades ago but not I guess I got lazy and have the shop do it.  I guess the one problem with changing your own tire would be the balancing of it.  Can we do that ourselves also?
Re: Tire Repairs??
« Reply #6 on: September 17, 2011, 10:36:04 AM »
The balancing part is no easier or harder than it has ever been;  a dynamic spin-balancer is great - except when it's not.  I had a BMW wheel come to my place that had been MIS-balanced by about 5 oz (20 standard sticky weights).  They didn't get the wheel (an open center single-sided swingarm type) to center-up on the spin-balancer.  For most uses, having your wheel suspended by it's original axle between two chairs (or whatever) combined with some patience will result in a quite adequately balanced wheel. No specialized equipment is required to get most assemblies to about 1/4 oz imbalance, and that is close enough for most purposes, excluding Turbo-Hayabusa's running on salt lakes...
 Like everything - the more time you are willing to invest in a project, the closer you will get to ideal results.  This is where you have the advantage over the guys at the motorcycle shop, yes, they have the equipment to do it quickly, but they HAVE to do it quickly;  you have all the time you are willing to spend to achieve the same result.
Re: Tire Repairs??
« Reply #7 on: September 19, 2011, 04:12:10 PM »
I'm up for a tire changing tech night.   After my last fiasco with changing tires, I purchased a set of tire irons and watched a dozen YouTube videos.  We should drag Wayne (Fast One) out for this because rumour has it that when he was a professional, he found it easiest to change tires by hand.
Re: Tire Repairs??
« Reply #8 on: September 19, 2011, 04:24:22 PM »
  I thought we could maybe use Russ' shop on a Tues. after ride nites are done. do one on the machine and a couple by hand. Good time to get your tires swapped free.
Re: Tire Repairs??
« Reply #9 on: September 20, 2011, 11:27:58 AM »
Sure.
Re: Tire Repairs??
« Reply #10 on: September 20, 2011, 12:50:08 PM »
Sounds good to have the tech nite at Rusty's if he is willing to do it.  I remember doing tires by hand in the not so recent days.  It was not too bad but a little tough on the hands but at least there was no pinching of the tires.  Although maybe I my hands were stronger then.
Re: Tire Repairs??
« Reply #11 on: September 20, 2011, 03:04:15 PM »
Thanks for being volunteered Russ!!!
Re: Tire Repairs??
« Reply #12 on: September 20, 2011, 04:49:34 PM »
Russ's "Sure" sound really enthusiastic.  A man of many words is suddenly reduced to mono-syllables.   What say you Russ?
Re: Tire Repairs??
« Reply #13 on: September 20, 2011, 06:57:22 PM »
Si. ;D
Re: Tire Repairs??
« Reply #14 on: September 22, 2011, 09:28:14 PM »
Why not make it even more interesting, do a tire with rim locks.
