Author Topic: Throttle Body Rebuilds  (Read 17894 times)
« on: March 01, 2026, 04:30:50 PM »
I bought a 2003 Moto Guzzi California last year and had all kinds of issues going from idle to 'on throttle'. The engine would spit and jump and when I was just teasing the throttle on the highway it would lurch back and forth.
A little bit of research told me this was due to the bushings and seals on the throttle bodies wearing out and allowing air to suck past the housing, messing with the throttle position action and sending the vacuum units all over the map.
The parts required to put everything back in order could fit in a tablespoon, 4 bushings and 4 seals. I found a fellow that had completed the task on a similar bike and followed most of his advice. I'll attach the .Pdf file for anyone wishing to have a better look.
The Coles Notes of this whole process go like this:
- Didn't require any heat to remove the fixing screws top and bottom.
- Take off the intake manifold and the rubber housing at one time - much easier to manage.
- Mark the throttle position sensor position on the body for easy refit.
- Do grind off the ends of the 2 screws fixing the butterfly to the shaft. I used my drill press (for stability) and a small Dremel  grinding wheel and took off only the first few thou.
- Note the way the seals should go back on. Chevrons to the outside. Not chevrons in like the last guy did to mine. Probably counted for part of the issues with sucking air.
- Bushings come out exactly as the other fellow suggests, being careful not to put too much pressure on the extraction process. They are split bushings so they will slide out nicely with a bit of pounding.(just kidding, go lightly here!)
- Re-assembly is straight forward if a)you remember where everything goes and b)nothing has dropped onto the floor where it disappears into the abyss with all the other bits.
There are a couple of good sources for the parts and don't let eBay trick you into thinking you need to spend $15 each plus crazy shipping costs. MY ChatGPT research assistant found these contacts:
The classic Moto Guzzi OEM part for throttle body shaft seals on many models is part number 25614997 or similar throttle body seal SKU (commonly referred to online under that number). This is confirmed by parts listings ? e.g., a Throttle Body Shaft Seal 25614997 available from aftermarket Moto Guzzi parts sellers.
Specialist powersports parts sites list 2003 Moto Guzzi California EV gaskets & seals including throttle-related seals ? you can contact them to request the OEM part number specifics. https://www.wheelerpowersportsparts.com/oemcatalogs/c/moto_guzzi_motorcycle_street_2003_california_ev/aftermarket_street-engine-gaskets_seals?utm_source=chatgpt.com
Bushings were $4 each this time.
So, all things considered, a fairly easy fix for a real frustrating issue. The most frustrating of all though was trying to wade through all the crap being offered by eBay and other sellers. "Probably Will Fit" as a response really doesn't do it for me.
The takeaway from all this is to give your favourite AI program a try when looking for this kind of stuff. Model numbers, part numbers and other relevant details can narrow your search and produce some amazing results.
Re: Throttle Body Rebuilds
« Reply #1 on: March 03, 2026, 10:15:13 AM »
I have been dabbling with AI (Copilot) when researching parts and repairs for my old Ironhead Sportster.  One would think with so much information out there to glean from, AI would have no problem getting it right.  I got some good information and some completely wrong information about brake fitting sizes.  In the end did things the old fashioned way; took the part to Chieftain and asked, "you have a fitting for this?"
Peace & Grease (the real kind), Dennis
« Reply #2 on: March 04, 2026, 06:16:52 AM »
I'd offer the same advice here as I would for raising my kids - don't trust anybody.
I've found over the last year that the quality of information received through the AI process is directly linked to the quality and clarity of input. In some cases I also ask the query to provide at least 2 sources for information given and more than one contact method if I want to ask more of the company.
Beware of the results that offer your parts at an unreal price. The thieves are lining up already to steal our cash and they are getting to be very proficient. I made a query to what I thought was a used parts place in Missouri and my first flag went up when 'he' responded with "Yes I have them, $100 including shipping" "Send me copy of your credit card, front and back and I will process" Hmmm.   red flags going up.  I wrote back and said "send me photo of you holding the parts and we'll talk" Then he says "Don't be stupid, I'm not going to do that for a $100 part".  Click!
« Reply #3 on: March 19, 2026, 06:32:55 AM »
SO - as an addendum - I managed to get the throttle bodies back together (with the help of a bunch of photos I took while taking them apart). I'm finding this sort of work on the bikes demands either lots of photos or same day repairs as I tend to forget too easily where things go and in what order.
The bodies are back on and I fire up the bike - still doing some of the same popping and spitting but not as much.  I decided to have a look at the valve clearances as this would be the next item on the long list of things that make the Guzzi go gulp.
Valve covers off and I see there is less than no clearance for every valve. About negative .05 - .08 mm. What the heck!
I know this one had a hydraulic conversion back to solids at some point so I started looking to see if they retained the hydraulic lifters and just changed the adjusters. They also snap off the adjusting slots at the top of the screws so us amateurs can't get in and mess up their classy work. Crap!
It's there that the information trail gets real sketchy. Some sites say all mechanical now and some say the lifters remain hydraulics. So I did what any good monkey wrench would do and said "Screw It" and walked away for a few days.
I have an idea since the bike is fairly high mileage that I might be looking at a case of valves receding into the seats and taking up all the available clearance. But since all 4 of them were the same it seems more like a planned event than a coincidence so I'll keep asking around to see what gives.
21 degrees here yesterday so the urgency to get it done is increasing
« Reply #4 on: April 04, 2026, 06:13:13 AM »
More on the continuing saga of pop and spit.
It occurred to me if the issue was too little valve clearance then it should be reflected in a loss of compression - right?  So I did the test and found 165 lbs in the left and 162 lbs in the right. WTF! Maybe there is still some hydraulic action taking up the clearance? I don't know what was done during the famous recall but I wonder if the original lifters were left in and the tappet adjusters were modified. That would account for the oil pressure taking up clearance.
The guy running one of the more popular Guzzi blogs in the USA won't let me post a question unless I make a 'serious' donation to his account so I think what I'm going to do is quit trying to find answers and get it ready to drive as soon as my rear fender is ready to re-install after being replaced due to a driver running into it while trying to merge on the highway and doing a shoulder check while moving forward.
Got to say, there is a lot of plastic and shitty connecting of bits to the fender on this bike. Plastic trim and push-on connectors that need to be carefully cut off in order to paint the metal. The ABS plastic tail-light assembly shattered when the fender was hit and the fender was creased so eBay came to the rescue.
If I don't get the valve stuff figured out I might have to revert to my old pals in the BMW corral this year if I want to do any serious riding.
« Reply #5 on: April 06, 2026, 03:49:19 PM »
Photos are a lifesaver for me--they always capture the part that I don't make a mental note of.  The other day I disassembled the Suzuki left handlebar switch for my GT500.  Took a photo at every stage of disassembly and I'm sure glad I did.  Once all the switches and bits were clean everything looked completely different.
P.S.  I think the term 'artificial intelligence' was coined to sell us super information aggregators.  So, the more esoteric the question the less accurate the info and this includes most techical questions on old bikes.  AI is definitely not 'intelligent' and I've found that viewer beware warning must be taken seriously.
« Reply #6 on: April 08, 2026, 05:46:21 AM »
Yes , the term 'intelligence' for me is a bit of a joke as I watch the adverts for the new smart products and an attractive 25 year old speaking into it saying "Siri - what's the weather today?" Getting the response "Cool and wet" she says "Siri - Do you think I should wear a sweater?"   So here I see the person passing on the responsibility to think for themselves to a software program. Just being lazy with a bit of stupid in the mix.
For me, ChatGPT is a decent research tool when given the right parameters to work in. I could do all the work that I give it but the time factor goes up by multiples of 20 or 30.
More time to ride........
« Reply #7 on: June 25, 2026, 06:32:11 AM »
So - a final note on the spit and pop stuff from my Guzzi.
I went through my list of possible issues when I came to the very last one (Before I loaded it up and took it to a bike smasher) I found an article on the internet by a fellow that managed to write in a style that even I could understand. Step by step moves to correctly set the throttle position sensor (TPS) and after about 30 minutes of set and test then reset and test I buttoned it back up and turned the key - Voila! it purrs like a kitten now and all the popping has gone.
I suppose when you dig through the symptoms it seems to be clear but when you're thinking old school carbs and ignition it isn't as easy to understand. What really amazed me was the number of so-called Moto Guzzi mechanics that I spoke to that had all the relevant information still couldn't/didn't think of the TPS.
The bike is now off my shit list and has been pressed into regular service for the summer.
