Author Topic: test photo loader steve crout  (Read 6158 times)
Admin
  • Administrator
« on: April 11, 2021, 02:47:37 PM »
Steve follow the instructions below to insert an image into the text of a post.
NOTE:--You have to upload the image first Then follow the instructions below.
To embed an image:
Right click on the attached image in question and "Copy image URL"
Go to the post with the URL in the clipboard, place the cursor to where you wish the image placed
Click on the "Insert Image" radio button directly above each post, when you open it "paste" the image URL into the popup
the result should look something like [ IMG]http://www.imagesource.com/image.jpg[/ IMG] (without the spaces in the IMG tag boxes)
Finally go to "Attachments and other options" below and uncheck the photos you have linked to, they will no longer appear below the post as before but the new "Inserted" photo will remain.
when you save your post, you should be able to see the image
« Last Edit: April 16, 2021, 03:15:31 PM by Admin »
Re: test photo loader steve crout
« Reply #1 on: April 16, 2021, 05:43:20 PM »
I think I haven't mentioned that I'm using a MacBook Pro. does that make a difference? I can't se the copy image URL on my machine.
Admin
  • Administrator
« Reply #2 on: April 18, 2021, 06:03:57 AM »
Steve, no matter what computer, tablet or phone you use there is a Copy/paste keystroke or mouse move.
Macbook Pro
Command-C: Copy the selected item to the Clipboard. This also works for files in the Finder.
Command-V: Paste the contents of the Clipboard into the current document or app.
« Reply #3 on: April 18, 2021, 04:32:26 PM »
.  like this?
« Last Edit: April 19, 2021, 09:10:27 AM by Admin »
« Reply #4 on: April 18, 2021, 04:33:03 PM »
Like this
nope
« Last Edit: April 19, 2021, 09:15:51 AM by Admin »
Admin
  • Administrator
« Reply #5 on: April 19, 2021, 09:16:40 AM »
You must upload a photo attachment first like this and post it just like normal.
« Last Edit: April 19, 2021, 09:24:56 AM by Admin »
Admin
  • Administrator
« Reply #6 on: April 19, 2021, 09:17:51 AM »
Admin
  • Administrator
« Reply #7 on: April 19, 2021, 09:24:14 AM »
Then "modify" the same post.
Then click on the tiny pair of binoculars Under the "B" above the post
which will insert this
img /img in square brackets
Then in between the brackets paste your copied url it must have the the complete www.princegeorgevintagemcclub.org......... address
http://www.princegeorgevintagemcclub.org/forum/index.php?action=dlattach;topic=3137.0;attach=3168;image
so that it looks like this
When this is done save it then go back to "attachments and other option" and uncheck the photo.
Save again.
« Last Edit: April 19, 2021, 09:28:53 AM by Admin »
« Reply #8 on: April 19, 2021, 07:02:19 PM »
Nah dead easy see I can even do it with your "grandkid"
thats a lot of work Terry!
« Last Edit: April 20, 2021, 12:05:34 PM by Admin »
Admin
  • Administrator
« Reply #9 on: April 20, 2021, 09:48:11 AM »
Once you have done it a couple of times it becomes pretty easy, its just remembering the right steps.
