Author Topic: Blast from the past  (Read 2344 times)
Admin
  • Administrator
Blast from the past
« on: April 06, 2020, 01:19:42 PM »
In the early 60's in Birmingham, England this was the "Scene". Late night at Alex's Pie Stand on the corner of the Inner Ringway. I was riding a 1960 BSA Super Rocket and had it somewhat customized. The English Motorcycle manufacturers gave little thought at the time to what the public actually wanted and just kept churning out the same old thing. Meanwhile the "Ton up Boys" had already decided, swept back pipes, clip on bars, racing tanks, rear set footrests. If they had money, update the carbs to Amal GP's, get a high lift camshaft installed along with Hi Compression Pistons, maybe even do the ultimate, Rocket Engine slotted into a Gold Star frame. A genuine Rocket Gold Star. Of course Goldie frames were hard to come by unless you knew someone at the factory. Other alternatives at that time were a TRIBSA, Triumph engine BSA frame, TRITON Triumph engine Norton frame, NORBSA Rocket Engine Norton frame or the ultimate merger, NORVIN a 1000cc Vincent engine shoehorned into a Norton Featherbed frame. Eventually BSA caught on and presented the world with the beautiful BSA 654cc Rocket Gold Star.  The last true BSA, after this came all the Unit Construction models. Never the same until the Triples came along.
« Last Edit: April 06, 2020, 02:00:56 PM by Admin »
Re: Blast from the past
« Reply #1 on: April 06, 2020, 05:45:59 PM »
Hey Terry - is that you under the "L" on the sign???????
Admin
  • Administrator
« Reply #2 on: April 07, 2020, 08:44:27 AM »
Hi Steve, it could be or not, on closer inspection I do see a couple of Super Rockets on the right side. Who knows we never knew what night we would be there, back then there were no fixed nights except for speedway on Friday in Birmingham and Saturday in Coventry. How are you and how?s the old girl running.?
« Reply #3 on: April 07, 2020, 05:31:16 PM »
Good Stuff Terry -  I'm hanging around Summerland for the required social distancing.    Had the brick out again today in 17 degree, sunny weather.  it was just like it should. be, the sweepers are done and the majority of traffic is elsewhere so the highways were nice.
Developing a little leak from the rear seal so I guess it'll be time to pull it down after this season.  I wanted to do the driveshaft/splines as well since it'll be apart. Just working on getting the R80 and the Atlas on a multiplate.
Let me know if you're coming my way later on in the summer.
