Author Topic: The Debaters  (Read 1605 times)
The Debaters
« on: April 09, 2018, 10:10:47 AM »
MODERATER:
"Be it resolved that BMW motorcycles being designed by the finest German engineers, would never have a short cut or otherwise poorly designed feature in a crucial part of their motorcycles; and in particular the wiring.
"Dennis, you are arguing against the resolution."
DENNIS:  The stock negative ground wire was thin gauge and bolted to a 10mm screw in aluminum, and shared duty as holding the speedometer cable in place.
The negative ground should be substantially mounted.
BMW engineers are as short-sighted as any.
kaziff
Re: The Debaters
« Reply #1 on: April 10, 2018, 01:07:56 PM »
Hi Dennis, the new ground strap runs to the rear cradle/shock mount.
Ground to the engine could easily be lost as the rear section is only bolted to the front cradle and the front cradle is where the engine/ starter are grounded?
Guy
Re: The Debaters
« Reply #2 on: April 11, 2018, 09:48:24 AM »
MODERATER:
"And defending the resolution will be Guy Hudson ...."
