Author Topic: Need audio device advice for movie nights  (Read 1382 times)
« on: November 10, 2017, 09:33:52 PM »
I've been looking for a device that will take the analogue output from the RCA plugs at the back of the Nellys pub television and transmit it to Neil's bluetooth speaker.  I think I've found it but would like a 2nd opinion.  Here's what I have in mind.  Thoughts?
https://www.amazon.com/gp/product/B072V5NXPY/ref=ask_ql_qh_dp_hza#Ask
Re: Need audio device advice for movie nights
« Reply #1 on: November 11, 2017, 04:47:12 AM »
Looks like it would do the trick.  Keep in mind the effective range of most all Bluetooth devices is only about 10 - 15 meters (line of sight, less if you're going through heavy brick walls or British Bike owners ) before the signal starts to decay and you end up with garbled junk.
The other consideration would be the ability of your Bluetooth speaker to decode the apt-x signal in order to get the low latency effect responses. If it cannot, then you'll get the dreaded delay in sound sync.
You could also take a pair of those old PC speakers that we all seem to have lying around, use their RCA jacks, 15 meters of speaker wire and get the stereo effect.
