Author Topic: ordering o.e.m. parts.  (Read 1624 times)
« on: August 21, 2012, 12:48:20 AM »
  If you go to bikebandit.com you can look at the factory electronic imagery. They have different part numbers but you can say go to the carb frame and no. 19 should be a needle valve set...etc. Then hopefully you will get the right part the first time. Cheers Mates.
Re: ordering o.e.m. parts.
« Reply #1 on: August 21, 2012, 05:39:18 PM »
Yes go to Bike Bandit to look at the factory diagrams but be careful if you decide to order from them.  I checked on a starter clutch for the Virago and they listed it as $332.00.  When I went to Yamaha to order the same parts they came in at $186.00 and I will get a discount on top of that.  I may have gotten a better price somewhere else but that would entail a lot of looking and comparing and I am naturally a bit of a slouch in that regard.
« Reply #2 on: September 01, 2012, 06:13:01 PM »
When I re-did the top end of my bike here is where I went, they had everything I needed.
http://www.powersportmarine.com/custompage.asp?pg=map
