Author Topic: a harley carb  (Read 1824 times)
a harley carb
« on: September 01, 2011, 11:36:51 AM »
I got a call from a Brian Rotar concerning a carb he has and was wondering if anybody was interested in it.  It is from a 1972 Sportster and he said the make was Electron (spelling?).  He no longer has the Sportster and so has no use for the carb.  He also said he has a brass air breather cover for the carb.  He wants to get rid of them both.  I don't think he wants any money for them but would like some advice or assistance with an electrical issue that he has with one of his bikes for it.  It is a 1974 125 Honda dirt bike that was streetable.  I think it was a Elsiniore (spelling?).  He had a problem with the signals and got a new relay for it but now they go on and won't turn off.  He was wondering if there is a member of our club who could help him sort it out.  He also has an 1971 Artic Cat mini bike 50cc called a Whisker that he said had a cork float for the carb.  But it is missing the needle valve and asked if we knew where he could get one.  So hopefully one of our members could help him out.
His name again is Brian Rotar and his home number is 250-562-5720.  He was working nights when I talked to him and you might have to try a few times to get him home.
Re: a harley carb
« Reply #1 on: September 01, 2011, 08:32:13 PM »
When you say they go on and won't turn off, I assume what's meant is that they don't blink? If the signal lights go on with the switch, that's 95% of the work done already.  The flasher unit is not cycling, so it is either defective, or more likely, it requires more current than the installed bulbs draw to cycle - particularly if they are small aftermarket or LED lights, or it requires more current than is available from the battery when the bike isn't running. The flasher relay has to get it's rated power to flow through and thermally cycle,  unlike the late electronic ones.
  If you mean they go on and then cannot be turned off, that's a little different and not the fault of the relay, but more likely the switch itself or, as you say, an underlying wring fault.  This seems less likely.
  The Lectron Carb was popular for racing bikes for a time in the early to mid '70's, but they are an iffy choice for streetability.
« Last Edit: September 01, 2011, 08:39:36 PM by Rusty Bucket »
Re: a harley carb
« Reply #2 on: September 01, 2011, 10:42:47 PM »
I am not sure if he meant that they stayed on without blinking or just stayed on.  I can call him and get some more info from him and relate what you say about it.  Yes it seems to me he did mention that the carb was for racing.  He just wants to get rid of it and maybe get some advice about his signal problem.   Maybe I will get it and clean it up and use it as a conversation piece.  Who know where that will lead to.
