Author Topic: Number 10  (Read 2061 times)
Number 10
« on: August 11, 2013, 11:26:15 PM »
  Out of an airplane with a parachute on purpose!! Finally got to jump. Almost no flutterbys , New plane with the door removed so turbulence is less both in and out of the plane. Good exit and arch, Clean opening at 3000 feet with a good chute, above 2000 for a long time, then dead air with a Quick descent. The most awesome ride down! First time jumping in shorts and a wifebeater with sneakers. Just right. View was a bit hazy but spectacular none the less. Managed a pretty good landing plus Reconnected with my skydive friends. Good day! CHEERS.
Re: Number 10
« Reply #1 on: August 12, 2013, 09:30:02 AM »
Sounds like fun.
Re: Number 10
« Reply #2 on: August 12, 2013, 03:43:13 PM »
uggg.. my toes curled just reading that post...
Re: Number 10
« Reply #3 on: August 12, 2013, 06:18:48 PM »
People think you die from the impact, when the chute doesn't open.  Not true!  You actually die from suffocation, due to a lack of oxygen from the long scream on the way down.  The furthest I want to jump is from the back of the pick-up.
PeggySue
Re: Number 10
« Reply #4 on: August 18, 2013, 11:10:51 PM »
Aw... that's the stuff!
So much better when the door is off. Have you done any 'corkscrews' on the way down?
Had me spinning higher than my chute, the last time I tried that trick!
Try it, you'll like it,
Peg
